When they tell you it's time to replace your brake lines...
MidwestMike
Southwest Michigan
GM's brake line issue, the main reason I almost didn't get another Tahoe.
The longest NHTSA investigation in history that did not lead to a recall.
https://www.freep.com/story/money/2015/04/08/general-motors-safety-brake-corroded/25460269/
Because of the backlash when these $2500, non-covered repairs came up, GMs solution was to make a set of brake lines that didn't cost a fortune and were pre-bent to be installed "easily".
If you find a good write up it makes sense on the install.
For $65 on Amazon you can get the GM/Delco ones.
  • Nylon Coating for better corrosion protection
  • Pre-formed and pre-flared for easy installation
dda1
