where does seafoam go
Danny_Z56
Franklinville NY
Run the entire bottle through the brake booster hose....If you have a PCV line to your intake than use that.In my case i really had no other choice than the brake booster hose.
Make sure the motor is good and warmed up/hot.
You may need someone to give the vehicle a "little" gas while taking in the seafoam.This will help keep the motor from stalling.Once the entire can of seafoam is gone shut engine off....let sit for a good 15 minutes.
After 15-20 minutes,start it and rev it in your driveway or take it for a spin.If you take it for a drive make sure you get on it from time to time,helps clean sh*t out.
When i did my Tahoe @ 138K i got plenty of smoke....
IMO if you dump any of this stuff in your crank case or gas tank you are just wasting money.Their are better products for this,like autoRX,GM cleaner,ect....IMO Seafoam should be ran through nothing but your intake.Thats were it seems to work best.
Z71JimmyK
