Where is my amp???
yates ™
Resident Apple hater
Iowa
IIRC you do not have an amp.
dropmech
dropmech
Puddle Pirate
Coral Springs
No center console. So are the tweeters and mids wired individually straight from the head unit?
yates ™
Iowa
A crossover somewhere I would assume. Whats going on?
yates ™
Iowa
Are you running them off the H/U? If so then the wire coming out of the speaker outputs on deck will wire into the new crossover and the woofer and tweeter will come out of that. It is the same if using an amp expect the wire would come from the amp.
dropmech
dropmech
Puddle Pirate
Coral Springs
What I'm trying to avoid is tearing apart the whole dash just for a simple speaker install. The way it is right now, is in the door itself, the tweets and mids are already wired individually as if they are already coming off of a crossover. Are you telling me that I can combine the positive from the tweet and mid and combine the negative from the tweet and mid back into only two wires in order to splice in the crossover that came with the speakers? Because there is only one positive and negative in the input side of the crossover.
yates ™
Iowa
What components are you using?
BK613
