Where to buy various interior trim pieces?
D
derekjl
some do. part numbers appears correct.
Kind of unrelated, but I was taking the window switch trim off of the front door and instead of just unclipping the round mirror selector switch I took the switch itself apart. There are 4 little white plastic tabs that make contact with the electrical piece to move the side view mirrors up, down, left, right. I cannot for the life of me figure out how to get the left or the right one back in the switch. Any help?
D
derekjl
sorry. never needed to disassemble before. i just replaced it.
Edit: Never mind I figured it out, had to move an extremely small tab to get the little white pieces in place. The reason I took it apart is because the up/down function of the switch is reversed. I have to press the up arrow to get the mirror to adjust down and vice/versa. Could this be an electrical connector issue?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
no that has to be a malfunction of the device or a flaw in the design. no way should wiring cause that unless someone has tampered with it.
D
derekjl
Ok so the last thing I need is the rubber trim pieces that go on the top of the door panel. I guess they'd be called weather stripping but it's only for the bottom of the interior glass. It's missing on both front doors, rears have them.
SunlitComet
OBS Jedi-Do Good
lmc or a dealer can get those for you. dealer parts will be a better choice as the quality is better. lmc might sell them in a set tho dealers can order individual pieces i think.
yep gm 15704112 $25.- however they are only showing the ones that match a gray interior left. if you have a different interior color just call it a color accent upgrade.
---------- Post added at 10:51 PM ---------- Previous post was at 10:47 PM ----------
http://www.gmpartseast.com/chevy/co...trim-side-front-tc160360116-l31m30k10706.html
D
derekjl
Yep, I have a grey leather interior. But, I thought the weather stripping was black? I thought they were all the same color no matter what color your actual interior is?
SunlitComet
OBS Jedi-Do Good
it is supposed to be a kinda of black soft fur on the window side, black rubber as seen from the inside but i believe it is attached and one with the grey strip you see on the door panel top.
D
derekjl
So as long as I have a grey leather interior these are the right ones? How hard of an install? Just take the panel off and pop them on? I thought I saw a video where they need to be stapled in place?
