Where to find custom wheel studs
awalts
Hi all,
I have a '98 2-door Tahoe, 4WD, Z71. I recently bought some new wheels for the truck that are thicker than the originals. Had them put on and the mechanic had a fit that the lug wasn't grabbing enough of the wheel stud. Says there's only 5-6 threads grabbing the stud, and that it was not good.
My question: Where in the hell do I find custom studs? I've looked and looked and looked. Surely I can't be the first person to have this problem.
Stock size wheel stud is M14x1.5, knurl 16mm, 45.5mm underhead length. I literally just need another 3/8" of underhead length and I'm set. Where can I find these??????????????????????????????
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
You can look into wheel adapters. They come pretty long, down side they will kick your wheel out more
Nauguy05
Hi all,
Stock size wheel stud is M14x1.5, knurl 16mm, 45.5mm underhead length. I literally just need another 3/8" of underhead length and I'm set. Where can I find these??????????????????????????????[/QUOTE
I drive big rigs and im always at the suspension shop. You may be able to have a good suspension shop cut you custom length studs .
Mike4400
