Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
My hose looks diff from all the other ones I've seen. There's something on the end of the hose? Is it the PCV? Does it need to be taken off before seafoam? It's pretty nasty looking. Is this the right hose?
the tube in your hand in last pic is the pcv tube, that in the end of hose is the valve. it wont want to come out after being in there so long, but pull and twist on it and itll slide out. i think poured the seafoam in a cup, and use the hose in your hand to suck it up
I just did a seafoam today through that hose. I don't think it's a pcv valve because mine didn't have anything in it. Just basically a spacer. Regardless, that's where I put the seafoam in and it sucked it up just fine.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
