Which drop springs???
BlizzardX23
BlizzardX23
Sacramento, California
issue...when I look at the kits...they all say for 2wd only...
I want the most drop...more then a 2/3
which Mcgauhys kit would I use? Im not seeing it
matt14
san leandro,ca
Hit up 55belairtim. He's an vendoor here and has mcgaughys. Also you can hit up norcalss, he sells djm. They can get you the right info.
Fyrcaptain
Richmond, VA
Hey Coopiesb....your sig says you have the GF 2/3....but your sig pic looks like
stock height?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i can get you 2-5 inch drop springs and all DJM Items
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i usually get rid of autoride due to the fact that wiht 5 inch rear drop the shocks are way out of their effective range. Its up to you i sent ya a pm on price :)
lowest for sure shipped anywhere
BlizzardX23
BlizzardX23
http://www.streetpros.com/product_info/category_id/7/subcategory_id/143/products_id/62787/
will that kit work perfect?
its 3-5 *FOR AWD*
# Front Spindles
# Front Torsion Keys
# Rear Coil Springs
# Rear Axle Relocator (whats this for?)
# Sway Bar Struts (whats this for?)
---------- Post added at 09:02 AM ---------- Previous post was at 08:52 AM ----------
I will be ordering a kit THIS week....I DO need a complete kit
I want spindles for the front as well..3 inch if possible.... (I AM AWD)
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
for 5 inch rear drop i really dont recommened the airride system to stay in. For the rear kit i like the djm one because it comes with new sway bar brakets to keep all that in check which is needed when going so low.
are you set on that?? the djm 3/5 honestly is a good kit and id stick to 2/3 if you want to keep autoride in.
sidenote here is the rear djm kit as you can see it shows why the kit is needed on your truck
http://djmsuspension.com/Instruction PDF 0908/Kits/RK2000.pdf
BlizzardX23
BlizzardX23
honestly...I just want it low...5 inches lower...if I cant keep the autoride, **** it...I wont...(does that mean it'll bottom out/tuck when I tow a boat?)
the link you sent me in PM didnt work =/
09YukonHybrid4x4
