which hid kit for 2015 yukon
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Okay soooo of course I forgot to order a damn harness...I had a 55watt innovited HID kit on hand so I put that in the lows... worked perfectly..Until the engine turned on lol, then they death flickered and both shut off.... So I guess I'll have to wait two days for this relay harness to come... Also where are you guys putting your ballasts? Mine are crammed up, but they fit all the way in the housings..barely lol
BMPNUGLS
Mid-MO
I wouldn't put the ballast in the housing. There is a lot of heat already created in the housing due to the bulbs which may damage the ballast. Most people such as myself mount the driver side ballast against the inner fender vertical wall and on the passenger side under the air box or on top of the inner fender - both with double sided tape or self drilling screws via a supplied mount.
I mounted mine with 3M Extreme Duty Outdoor mounting tape and that stuff is STRONG!! Very good adhesion and holds the ballast perfectly.
You may want to look into capacitors/error cancellers to avoid any flickering or error codes - These are supplied with most GM specific kits nowadays.
Daddyyukon92
