Which Michelins?
FrankU
Babylon New York
Mich used to be the best tire around , bar none. But then again that was a long time ago.
iLikeEggs
Potato!
Oregon, USA
I like michelins but around here they dry rot and side wall crack like crazy
I never had any Michelin that dry rotted. Drywalls can crack though when when vehicle sits for a loooong time. If they did crack and are still within warranty, Michelin would probably replace them. However, the rubber covering the side wall part of the tire is only a cosmetic skin and not structural.
Any tire can have cracked appearances on the side wall.
iLikeEggs
Potato!
Oregon, USA
I've heard the complaint about dry-rotting and/or sidewall cracks on Michelins but do not know if those issues are confined to any particular model of Michelins. At the same time, many people rave about the ride/handling/longevity of the Michelin brand. I had great experience with the tires that I ran but that was roughly 6 years ago (on my Jeep, now long gone) and I don't recall the model, but they wore like iron.
I believe that products marketed & sold through warehouse club retailers MAY be of lower quality in order to meet price-point or margin objectives.
No true. If it's a brand name tire the brand has to stick behind it. However, the mileage warranty on pretty much all tires are arbitrary and more marketing than a reflection of the actual mileage that a particular tire can last. Mileage warranties are smoke an mirrors. It is feel good thing. Buy a tir based on load, tread wear, traction and temperature ratings.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
That appears to be a tread separation. Take it in to a Michelin dealer.
I work for a dealer and these are oem equipped tires. There are a lot of run arounds that the customer and dealers have to go through and most the time it's not worth the effort. 90% of the time customers end up going with another brand due to the cost. For example 1 17 mich 91v rated can cost 179 per tire where customer would rather spend the money for the cost of 2 michelins and get 4 tires with an alignment.
I did 4 Michelin pax tires and a alignment for a customer and the bill was over $1000. And they only went about 30k miles on them. Talk about crazy
mike1944
Glide, Oregon
Baloney. I have Michelin LTX M/S2's on my Denali and they are great tires.
If they were all cracking and falling apart they wouldn't be so highly rated on Tirerack and other sites....and Michelin would be out of business.
sumo
rhode island
Like i said. Not all do it. Also take into consideration area location. I live in New England.
08HoeCD
08HoeCD
I'm sure it's not all Michelins, and I'm sure the overall brand includes great tires. But I've heard from a number of members on here and on other forums who have experienced cracking sidewalls. These are not made-up stories. I just wonder what circumstances cause it and/or if there are certain tire models where it is more prevalent.
Ciro
I would like to see the manufacturing code of those Michelins with cracked sidewalls.
iLikeEggs
Potato!
Oregon, USA
There could also be recall from Michelin. He could inquire at Michelin customer service. They will need the tire size, model and DOT numbers stamped into the tires. I used to be be Michelin dealer. I've seen Michelin give pro rated adjustments for things as small as side wall cracking. Sometimes they will request the tire, likely so if it's a case of tread separation. However if they determined, that the tire was over heated from doing burn outs he won't get zip. Other things that will void the warranty (like with most manufacturers) are wear and damage caused by misalignment, worn suspension components, bent rims and impacts. As always, your mileage may vary.
Damatulli1
