Okay so a decision has been made on the new retrofit configuration ...
We're going to go with LS460 projectors, 50W ballasts, and [secret] bulbs, in the lower big reflector bowl.
Amber/white led switchbacks in the smaller upper bowl for ts/drl.
Everything else stays as is.
This is what the LS460 projector looks like, it comes enclosed with its own oem shroud (the 2nd retrofit): http://customlightz.com/?p=p_224&sName=sequoia
The last decision I need to make is which oem housings to use that will complement the 460s better.
oem denali:
oem base yukon:
The difference is that the base headlight are all chrome (chrome/brushed in denali), and the side marker is fully enclosed by the amber strip (partially enclosed in denali).
Here's what mine looks like on the truck right now:
And Rai's Denali retrofitted (MH1) with the base headlights:
The thing is, I prefer the more understated Denali headlights, but I'm not sure which will flow better with the all chrome LS460 shroud.
Thoughts?
oem denali:
oem base yukon:
Thoughts?
