Which transfer case fluid and how much?
Grimes
Really 26 views and nobody knows.:wtf2:
In the defense of those 26 (now 27), the lack of a descriptive title means anyone would click it. For all we know you just put in a turbo'd diesel with a no-gear transmission.
I can't help you with your question (sorry), but if you don't like seeing your replies being lower than your views, then make a useful title.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
good thinking. I changed it from "01 yukon" to "Which transfer case fluid and how much?"
Hopefully he can get some answers soon
afpj
I have a 02 5.3l 4x4 (not permanent awd). Check your manual to be sure, but the blue auto track II fluid is likely if similar setup to mine, and it takes just under 2 quarts. You'll need a tube/hose to get the fluid in as my filler hole sits right next to a cross member so pushing fluid in with a nozzle adapter won't fit. Good luck.
Mechahead
Dallas, PA
It takes 2 quarts of Auto Trak 2 as stated above. Don't put in ATF. As also as stated above, its a pain to get in there.
