Whine from engine
DirtDigler
Noise just started. Sounds like pulley bearings going out? Cant really pinpoint it though. Happens at idle and increases with rpm. Any tricks to figure it out? Power steering is topped off, not running hot, all seems to be good.
Take the serpentine belt off and spin the pulleys and see if you can narrow it down, if it is not from the main belt then try the ac belt, pretty typical for the ac tensioner to make noise
DirtDigler
DirtDigler
Thanks. I have a stethoscope but really dont want to use it near any spinning parts! My guess was the AC too. Good idea on removing belt, I will try that.
wsteele
I have a buzz/whine rpm sensitive (goes up and down with RPM's). When I was diagnosing it, I finally determined when I shut the radio off, the whine goes away. I assume it is either noise being generated by my 12 y/o alternator, or a bad filter in the radio head. I will fix it one of these days. :)
You might just turn the radio off just in case.
OR VietVet
Multnomah Falls
Military
Willamette Valley
The stethoscope should have a long straight metal probe that you can carefully put the tip at the back area of where the pulley is spinning and not touch the pulley and that is right where the bearing is, inside the housing it is in. Being careful is key but in literally thousands of times, I have never had a problem getting there.
OR VietVet
Multnomah Falls
Military
Willamette Valley
You heard her say, "Without thinking". If not qualified or smart enough, any person, male or female, should stay out of an engine bay with the engine running. Couple times in my post I use the word careful. So yea, I would tell her that for sure! I feel bad for her.
Hell, there are people out there that think oil changes are easy, right up to the point where the car falls on them.
So many people on this forum want to do it themselves to save money but if unsure they need to ask here or be shown by a qualified trained friend. Stay safe.
electronics101
