Whistling sound under the hood?
Crowder99Yukon
Only at low speed, RPM doesn't matter. Makes whistling sound when going slowly but goes away when you come to a complete stop.
Changed the belt last week, needed to be done anyways.
Donnie Yukonie
Yates Caretaker
Ive had the same issue for years , does it sound like a small supercharger almost?
Crowder99Yukon
Crowder99Yukon
It does actually, hadn't thought about it that way but yes. And it goes away when you come to a full stop?
Sent from my HTC One S using Tapatalk 2
Crowder99Yukon
Crowder99Yukon
Def not a window seal or weatherstrip. Any other ideas?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you checked the seal under the back of hood mount on the firewall right?
other ideas are a induction duct leak, if installed a cai may whistle sometimes sometimes if you also have a ported throttle body the the blade mode done.
this is whistling right not a squeak?
Donnie Yukonie
Yates Caretaker
Years ago I had a mechanic at a dealership tell me it could be just the "sound" of the vortec system working ,and that it was normal…. Yea
Crowder99Yukon
Crowder99Yukon
Yes it is a whistle. And I did check that seal. Have checked every seal I can find on the front of this truck
BurbyRST
