First I would like to say I am new here and I've already found out how to resolve most of the issues I'm having by lurking around a few days. the two issues I cant resolve right now are 1. a slight rocking in the back rest of the drivers and passengers seat no idea whats loose in there. 2. my right rear door window sticks for a second then slams down about an inch and a half when you roll it down. I pulled the door panel off yesterday, and noticed some slack in the cable on the regulator when the window is rolled up and gets REALLY tight when attempting to roll it down. I'm not sure if the regulator is bad, if the cable/spindle need to be rewound, or if i need to replace the motor. Any advice would be very helpful I took a video off the window so you can see the issue. BTW this is on a 2000 Yukon SLT
http://youtu.be/pGI35Y4-YAk
