Wife's '08 Suburban LTZ Grocery Getter Project
felixgun
Lafayette, LA
Thanks for the heads up Matt. My factory HID projectors in the esky are actually 4300k and I doubt V-led's has those so I guess i'll have to go with 5000k.
Robbie- what's the coupon code for the 15% off? :)
---------- Post added at 02:07 PM ---------- Previous post was at 02:05 PM ----------
Yep... 5202. V-LED has a 15% off coupon code right now and these were on sale for $67+15% off.
Also on a side note, on your oem esky tails, how did you get those reverse light LED's put in? Mine wouldn't fit. The hole to put them in isn't wide enough so I ended up putting them in the aftermarket LED tails on the Avy which fit just fine. Did you have to dremel the hole to make it wider/bigger so they'd fit?
THE YETI
THE YETI
Director of Operations
South FL
NOTIE15 is the code. Ends today or tomorrow.
Our LEDs fit right in to the housing? No issues whatsoever.
felixgun
Lafayette, LA
Thanks for the code. Hmm that's odd. I got the exact ones you told me about and they don't fit...
THE YETI
THE YETI
South FL
I put the V-LED 5202 5K LED's in the wife's foglamps and I am more than pleased with the brightness and light output. Quite shocking to say the least! Repped for those badboys!!!
THE YETI
THE YETI
South FL
Sad day boys...
Bye Bye Burban!
Click to watch video...
felixgun
Lafayette, LA
^^^I just watched it on my iphone actually... if you can't view within tapatalk, click on the ">" arrow in a blue circle in the bottom right hand corner of the post labeled "More", and then click on "View in Safari" in the top right hand corner. You can then view it in there also.
Rockytfox
Worked like a charm. Sorry to see that burb go. She sure was purty!
cwmccray_jr
