Will 07-up rear z71 springs work on my 2001??
01YukonXL
Jasper, IN
Trying to find out if the z71 springs from the 2007 and newer body style will work on my 01? And if there is a difference if they are from a tahoe or Suburban. The GM part # is 15234633. I'm removing my autoride and putting new Bilstien 5100's and I want the heavier payload springs on the rear. Any help would be much appreciated. Not having much luck searching.
Goodinblack
I Like Tacos
Dirty South
Z springs are stiffer to handle off road situations. It is not a towing spring exactly. You should look into airlift 1000s too.
Pedders makes a real towing spring.
Blazed
Accepting Donations
X2
Pedders does make a towing spring for the nnbs and it to would work for this guys 01
01YukonXL
Jasper, IN
I have a trailer that I pull occasionally and I don't want the rear to squat to bad when I have load.
NinoRiojas
