Will 305/65R18 Fit?
02_Tahoe
Maryland
Looking to do either the Supreme Suspensions leveling kit or Rough Country leveling kit which gets 2-3" lift.
Wondering if 305/65R18 BFG AT KO2 tires would fit?
Depends on width of wheel, that size is 33.6 and I have 33.3s on a 10 wide and I had to do some trimming and sometimes backing up over a bump I'll hear it slightly rub on the wheel well liner. If you go with 9 wides and some trimming on the lower valance then yes you can do it no problem, even 10 wides if you can deal with slight rubbing at full lock backing up
B
bluebear15
wisconsin
Thanks! They will be on '14 Silverado split 5 spoke rims which I thought were around 9" wide. So basically either way it requires a little trimming.
What lift do you have?
02_Tahoe
Maryland
I have 3" keys and 2" spacer in the back. The only trimming needed isn't even that noticeable
1stRC
