Will Crank...won't run
foreverfalcon40
Any car will Crank all day...but you need Spark and Fuel to make it run
just figure I state that I know this b4 I start my thread to make get to the point.
The other day she ran FINE. Woke up went to drive her and NO...Crank...turn over then Boom Dead.
I let it sit for a few hours while I brain storm. Checked all my fuses under the hood (Ignition and ECM and battery too in order to pull out the IGN 1's) None were popped and I did the same in my interior panel. None were popped.
Put them back in and BAM she started.
I'm kinda cautious at this point b/c everything is breaking and going out on its way.
Do you think its possible that a few actually came loose? Don't recall any of them as I was tired...late at night when I did the fuses.
1) Possible fuel pump? Its been replaced by the previous owner...I don't know when but I'm just saying...
2) When I installed my Janzer TB I shorted my MSD BOX aka I fried the SOB so I sent it out to get repaired and then re wired the igntion back to stock (kinda Plug and Play...you get the point). I thought I fried my Ignition Module inside the distributor) Apparently not.
Anyway...thoughts comments...on wtf happened...wtf is going to happen? I HATE ROADSIDE REPAIR!
nytahoe
"Tha Butcha"
new york
i know on the older cars its a plug that goes threw the fire wall fuse on the inside some times the bolt can get lose . if ur truck is like that make sure its all clean and tight
foreverfalcon40
foreverfalcon40
so far about ten start ups...nothing so far so good!
that plug inside the dash I assume?
96ProCompTahoe
IN
She's just showing you she still runs the show! haha mine acts up every once in awhile, moisture gets under the cap and it starts arkin.crank but no start. clean it out, back to normal.
Kingjackpot23
