Will Rough Country 2” lift work with Magnetic Ride???
olyelr
Elk Rapids, MI
@olyelr what kind of lift do you have? Is it just the lower strut spacer? The U shaped deal? Seems like that’s the least intrusive way to go. I would imagine just 1-1.5” isn’t going to throw off the driveshaft like a 3-4” lift would. My plan is to just throw on a lower strut spacer until the official magnetic ride kits come out. What tire size are you running on your 1.5” lift Olyelr?
Yep, lower strut spacer. 305/45/22 tires…had them on a stock height with absolutely no rubbing issues.
Heres a little write up i did…
https://www.tahoeyukonforum.com/threads/mzs-1-5”-level-kit-on-‘22-tahoe-high-country.131463/
olyelr
Elk Rapids, MI
A level or lift will not change the driveshaft angles at all unless there are differential drops supplied with the kit (like a rough country 6”).
A level (without a diff drop) will change the axleshaft angles, however.
L
LekGMC
Thanks for the info. Your truck looks great! I’m glad to hear the strut spacer is working for you and to see the tight clearance to keep an eye on. Thanks for the link
R32driver
Have you gone back under and looked if there's been any contact between that bolt and the axleshaft boot? I'm curious if they actually ever make contact or if the dealer was just blowing smoke cause the upper kit takes longer to install and they make more money...
olyelr
Elk Rapids, MI
I havnt. I should check it out soon again I suppose. I don’t suspect any rubbing…but also am not 100% sure.
03suberban
