Will these rims fit?
97hoez71
I have a 97 hoe and was wondering if these rims would fit okay.
they are 15x10 with a 4.5" backspacing
my truck doesn't have a lift or anything. Just stock
setty7
i would say probably not, you would have to trim a good bit maybe? dont take my word for it though. someone else should chime in
97hoez71
the tires it would come with are BF Goodrich Trail T/A's 31x10.50R15
EastTXYukon
Longview, TX
The width of the wheel is going to be your biggest problem. 10" wide wheels don't really fit on our trucks real well unless you have a lot of lift.
An 8" wide wheel would do better for you, especially if you're staying stock height. Plus a 10.5" tire mounted on a 10" wide wheel is kinda weird
97hoez71
I bought them anyway and they fit nice no rubbing or anything didn't have to trim. Just wondering why they stick out more in the front? are all hoes like that?
992door
Greenville, NC
Yea that is normal. The front is just a little wider than back. If you want you can run spacers in the rear to match it up if you are that picky
Pictures?
Z71JimmyK
