Will These Tires Fit
tx01tahoe
TX
It would be a super super tight fit. That is almost a 37" tire, and pretty
wide for a OEM wheel
Red_Raider
Red_Raider
Derby, Kansas
I wasn't sure since my current tires are 275/55 and it is only 60 series so I wouldn't think it would be that much wider.
Denalixl364
im running a 305/40/22 and it is a tight fit. My truck is also lowered 2/3 I had to cut the rear wheel well to keep them from rubbing.
tx01tahoe
TX
The 60 is actually referring to your sidewall height, which is the percentage of the tire's width which is the first number in mm. So 355mm is 13.95 inches wide. So 60% of that is 8.37 inches, which is your sidewall height.so if you multiply that by 2 and add 20" for the wheel diameter, you have the tire height.
So that tire is pretty much 36.75 inches tall and 14 inches wide. Just thought id share my knowledge as a tire guy.
---------- Post added at 10:15 PM ---------- Previous post was at 10:09 PM ----------
Because of the offset on OEM wheels, it'll also be harder to go with a bigger tire like that, you run into problems with the tire rubbing in suspension parts or the inner wheel well. I think you'll be much better off with a 325/60/20 or a 35-12.50-20.
Red_Raider
Red_Raider
Derby, Kansas
Thanks for the information. I did a comparison using discount tires website. I know that I would be getting at least 2" more in tire height. So I guess I need to call around to see if someone will mount them for me.
Ok I will look into that. I wasn't sure if the 12.5 would work.
tx01tahoe
TX
I honestly don't think those tires will work well with OEM wheels, let alone fit on the Tahoe. I guarantee you those tires on your OEM wheels will rub on the suspension. 14 inches is really wide for a 8.5 inch wheel.
The height isn't really the biggest issue here. It's the displacement of the tires on those wheels. Maybe call a Discount Tire, America Tire, whatever it is in Cali, and see if they can test fit something for you to make sure it works before you spend money on something that may be more work than you think to be able to fit, such as wheel spacers etc. I work at Discount Tire so I've had this happen on tons of trucks that come in.
http://billetwheeladapters.com/6-lu...ter-gm-fitment-6x5-5-to-6x5-5-1-25-thick.html
Red_Raider
Red_Raider
Derby, Kansas
Sorry I posted that last post before your edit. The more I think about it I will probably just go 305/50(5)/20.
nashon79
