Windshield wipers only work on high for 2001 yuk
dec322
B'ham AL
My wife just called and told me the problem. Right now I don't know anything more (sounds and stuff like that). I also own a obs chevy truck and I had to replace the pulse board because of usual wiper problems with those trucks.
Does the 2000 and up trucks have the same problem?
bkboatnsleds
McHenry, IL
I had some wiper module replaced on my truck once - Was still under warr. - My problem was that they wouldn't turn off at all - but I bet its the same module.
D
dec322
B'ham AL
Thanks for the reply. Do you know where the module is?
I turned the wipers on and there is no sound at all. If you turn the switch to high then the wipers come on but they immediately stop when you change the mode. The do not even reset and return to the bottom of the windshield.
bkboatnsleds
McHenry, IL
I'll have to look at my service paperwork I think it has a P/N on there as to what was replaced.. But sure sounds like the issue.
D
dec322
B'ham AL
Fixed Update: I don't think my truck has a "module". I checked all fuses and they were good. I decided to go for the wiper motor and I pulled the pulse board off of the top. Here I found a broken electrical connection on the board. Unfortunately these boards are not sold apart from the motor (I did find a place online that sold them but the cost was almost the same as a reman motor). I bought a new motor and installed and everything is normal.
Hopefully someone will find this thread and use it for help in the future.
cag
Thank you! This was very helpful. I have the same problem. Looks like a new motor should resolve the problem. Thanks for taking the time to respond back to help others like me. I created this account just to thank you. Be well my friend.
LazyWave
