Wiring Help Needed
firefighter23
Stanhope, NJ
I have a 2002 Tahoe LT w/ Autoride, and I am trying to hook up a few interior LED lights that I want to come on when I start the truck, but not have power when the key is off. Does anyone know where i can access 12V+ which is on, only when the truck is running? Thanks
steven johnson
wisconsin
fuse box. i think you have a fuse box under the dash, or on the side of the dash driver side. its been a why since i had one. good luck.
baldd86
On my 04 under the driver side by the parking, brake there is a black box with with a plastic nut. You take that off and tap into a gray wire with a black line. Its under a brown plug. Your truck may be a different color wire though
Sent from my SPH-D700 using Tapatalk
Gotcha12
