Wrenching in the gravel?
Walchit
Walchit
I could use a little bigger piece, but it's 1000 times better than gravel. I got the back done, except for the sway bar, because it has a broken bolt and someone has tried to drill it but put a hole right next to it instead...
Gonna do the front, then go beg my dad's friend to help me with the sway bar and anything else I f*ck up, lol.
Walchit
Walchit
Will do!
I'm gonna move back to my thread with the rest of these pics if you guys get bored.
If those sway bars are Hellwig, you will need a second jack or a second person to get the front sway bar installed. I tried for over an hour to get the sway bar lifted and in position to get the first bolt started, and I could not do it alone. I finally got a second jack, and I bungeed the center of the sway bar to the jack and lifted it into position to get bolted on.
easymoney
I'm about to do the suspension on my XL, and I have gravel outside of the garage. I am wondering if anyone has tried laying tar or liquid asphalt over the top of gravel, or maybe doing a chip and seal type of thing. I wanna be able to move my jack around easier.
My other thought is a big piece of carpet, which is probably what I will end up doing for now. Maybe a few smaller pieces so I can move them inside if it rains
I use either cardboard or the windshield shades to roll around on to keep gou out of the dirt/rock/mud…They are soft. The windhield shade is very slippery it suprises me how i can slide around under there. I would get a piece of 2x12 to put the jack on so it doesnt sink
calsdad
I work in a gravel driveway as well. It's a hard pack gravel though so things don't really sink down that much. For the jack and jack stands if I'm worried they might sink I just throw down a piece of plywood under them.
For actuall working - so I'm not dropping tools in the gravel and having to kneel down in the gravel - I bought some of those heavy duty 3ft x 4ft rubber horsemats from Tractor Supply. I just leave them outside and the weather doesn't seem to do anything to them. They're heavy to move around - but are a nice surface to work on when I need to kneel down and stuff like that .
onetimejob
