Yates's Cadillac adventures
THE YETI
Director of Operations
South FL
I know you would. I'm just not there yet. [emoji41]
THE YETI
South FL
Yeah.. About that hanging out thing. Need to keep a leash on that puppy.
yates ™
yates ™
Resident Apple hater
Iowa
So no pic updates but finally got the wiring ran to the battery and the wires for the upcoming head unit install. Next step is to enlarge existing holes for bulkhead fittings through the trunk floor, wiring up the solenoid for the tank drain, start mounting parts, and figure out sensors. Was really hoping to be done with this by this weekend but so much had came up to keep me away plus the GF and kiddo have been sick. I just want to drive it before it snows... :(
THE YETI
South FL
i think you should just to show up Jacob
yates ™
yates ™
Iowa
Finally had some time to work on the car tonight and an extra set of hands I needed. Had to redesign the bracket since trying to bend 3/8 airline 180° was the dumbest idea ever, the powdercoater forgot to do the piece today so can't get everything bolted down... Anyways tank is bolted down, isolators are bolted through the floor, bulkheads bolted, and drain valve put into place. Going to try to get airlines ran tomorrow, luckily only the rear bags need new lines ran, write up the drain valve, and mount the relays. Hopefully Monday the mount will get powdered and the I can bolt it down as well as compressors and valve block bolted down then run the final lines.
Cody13Wayne
