Your Vehicles as they sit now....
01Konvict
Boats n Hoes
Raleigh/SML
Mini D2S 4.0 running Morimoto 5.5k bulbs. These are eagle eyes headlights and when I tried to removed the inner part from the lens, I couldn't get it to come out so I stopped fighting with it and left it alone. I also had some dummy projectors to put over the drl/turn signal to make it look like a quad retrofit, but like I said, I couldnt get the inner plastic separated. So I just went basic to finish it up.
And I'm not REALLY big on chrome ( this truck has WAY more chrome then all my previous vehicles combined x3, but the denali style headlights look 100x better) so I'm not pressed on the chrome fogs, and they go unrecognized which is nice.
Sent from my SM-G935P using Tapatalk
Well good projectors. You can get it back apart. Just use a plastic knife around the edges and it should pop out. The amber takes some effort. Best way to get it out is put a rag over the end of a 1/4" socket extension through the bulb hole then pop it with a hammer. Once you get that all apart you could paint the inside black to match the fogs.
93blkongreenpro
The high beams are monstrous! The low beams could be wider, but the fxr un my protege are 7 lane wide and has spoiled me. But for ease of installation and aiming, ill take the easy away out with the mini d2s if i had to do it again.
DirtyBlackHoe
Thomasville, GA
What is your setup again? That looks GREAT
Sent from my XT1585 using Tapatalk
Jbvette96
