Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Fit and finish is OK. The area I'm concerned with is under the grille. You can see the high spot between the M and the C of the grille. The instructions say to use two sided tape. I hope this will flatten that area out. I'll have the grille off for final install so I should be able to massage any problem areas.
I was hoping it would cover the skid plate more, that's my only gripe.
I've been looking for a while, and had seen this before. I like it a little more than I thought once you set it up against yours. How's it coming along? Anxious to see it completed.
i believe an OEM ss bumper of an ss silverado would fit on the yukon because it has that knotch cut into it for the grille to fit in that bumper looks good too tho never seen that before hope to see the final results
I will need a closer look. I thought that their notch isn't 'deep' enough to match Yukon grill. Guess I will have to park beside one this wknd to compare. I assume Silverado grills are same shape on either ( SS or non ).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
