Yukon Denali Build
grantbgood
grantbgood
Replaced the low beams tonight so now all lights on the vehicle are 6000k. 1st picture is low beams and fogs. 2nd picture is lows and highs. 3rd picture is a comparison on the garage door. (Driver is 6000k and passenger is 4300k)
5F306BEF-81AD-4F03-837F-F1B04B75ABCC.jpeg 102E6988-75E3-4A1D-8506-F66A613CB290.jpeg 800AB874-23ED-495A-BD17-96C01B1CB0D3.jpeg
Short_Haul
Lookin good! That light output is impressive! What tires are you planning on getting? And are you sticking with the 22’s or going smaller? Also did you install the lift yourself?
BrentS
I will be replacing the stock low beam HID’s that are around 4300-4500k with aftermarket HID’s with 6000k tonight to better match the DRLs, Highs and Fogs. I will try to update with pictures soon!
What did you use for aftermarket HIDs?
grantbgood
grantbgood
Thank you! I am still shopping around for tires looking at the different options available, I am thinking either all terrain or mud terrain tires. I am going to keep the 22” wheels and yes I installed the lift within a couple hours in my garage.
Becada
Looks great! I recently purchased the Suspension Maxx 2.5" leveling kit myself but have yet to install it. How high did you end up going in the front? Did you go with just 2" or did you go all the way to 2.5" and remove the UBJ to do so?
grantbgood
grantbgood
Thank you! I ended up going 2.5” by using 4 shims on each side, I had to loosen the upper ball joint but it was not too hard to do so. Just make sure to get a alignment afterwards my angles we’re adjusted pretty bad.
eod_tech
