Yukon Denali XL Manual Airbag Install Questions
OK, so here are my thoughts/results of the "helper" airbag install on
my 14 XL Denali. IT DID help the little bit of sag that I did have.
I put in 30 psi into the firestone bags, then hooked up trailer with
weight distribution bars.. Then started the Yukon... This order seemed to
help , rather than engine running the entire time.
The airpump definitely ran- but didn't have to KEEP running after hooked
up and leveled out..
The job was certainly a pita as I had to remove the coil springs to get the bags installed.. Of course I did a lot of cleaning, etc under there.
I put on the new ACDelco shocks - Z55 air ride .
The ride unloaded is a tiny bit stiffer with the new set of shocks unloaded.
Overall, I was really happy with what I did. I still need to to adjust my
Equalizer 4 point sway/weight dist hitch a tiny bit to fine tune...
But happy with the ride...
BTW, I did get the new upgraded rear brakes on too... Fronts will
be on soon. Along with the Edelbrock Etec SuperCharger and Kooks
Headers & Y-pipe with cats...
I could have used more power, so that should take care of that part.
We want pics. Especially after the blower and headers. No pics= didn’t happen. It’s the rule here lol.:pics-stfu:
Foggy
KS
I will do my best !!!
I didn't do any pics on underside because it was so filthy.
I bought it out of oklahoma.. No rust... but was on red dirt
roads all its life from what I see... I've been cleaning and cleaning
since I bought it in July !!!
I've got all my upgrades purchased and sitting here... Solid Hummer
motor mounts, Deep Alum trans pan, etc etc..
Just not the time to get er all done!!
cwmccray_jr
