Yukon/Tahoe Tail Light Plug P/N
CTX-SLPR
College Station, TX
Howdy,
Does anyone know the P/N or the connector family for the tail light connector? Heavily considering the GMT900 Escalade tail lights and trim panels to replace my leaking stock units but don't want to cut up the existing harnesses. I'm quite familiar with depinning and splicing wires so want to do all the work on the Escalade light side and just replace the connectors.
Thanks
Fless
Super Moderator
Elev 5,280
C
CTX-SLPR
College Station, TX
For connector info, start here (I'm not sure if I have the right model selected):
Then scroll to the top and select the vehicle of interest, taking note of where the connector views are in the menu tree. You can compare both connectors using those views.
Looking for the larger 6 pin connector that goes to the body. It's not the typical GM 150 or 280 series as far as the physical plugs look like and the plugs are different pin counts between Tahoe/Yukon and Escalade.
Fless
Super Moderator
Elev 5,280
