Z55 rear air options
HACK BLOCK
NYC
What’s up guys so I recently replaced my rear z55 shocks less than 2 years ago with acdelco and just found out one bag is shredded and leaking bad. Don’t got the money to replace with Oem/acdelco/arnott right now so I was looking at other options on rock auto or even Amazon. What is everyone opinion on the other choices on rock auto like fcs, cardone, spk, westar etc. or no name air shocks on Amazon.
I recommend replacing with OEM shocks for the best results, and they are easy to replace. Try RockAuto.com or GMPartsDirect.com, and the price of the shock should be around $350. Then, you will be covered under GM's lifetime warranty for the shock.
petethepug
Michael
SoCal
Still under warranty then. 1) Contacts seller. If seller is clueless contact eBay for refund. Ultimately a/c Delco is the warranty holder so they’re obligated to get you a new set.
Be sure to get names and phone numbers of individuals you speak to in the first two calls. A/c Delco may inquire on your behalf to check complete your warranty exchange.
If something goes sideways, send me a dm, I’ll wrassle it right for ya.
Ali Khalifa
