Z71/limited fog lights
Tbruz
Windham NH
The fog lights themselves are available online at a bunch of places for around 100 bucks shipped.
The 2 mounting bucket are the issue, they're NLA and not readily available.
The switch itself is also NLA but you can find that occasionally.
If somone is creative they could probably figure out an alternative to the mounting buckets using sheet metal.
Tbruz
Monstar_est87
City of Angeles
Hey guys... As u may know I drive a LIMITED, stock with bumper lights... I have the vertical fog switch and wish to convert to a horizontal fog switch... I have both swiches, however the pins in the switches are different as well as the plugs... And im pretty sure so is the wiring... Does any 1 have the wiring diagram for the horizontal..? E.I. Wire colors..? Which wire color goes to wat pins..? Ill post up pix in a few hrs or so...
Monstar_est87
City of Angeles
Vertical switch
Horizontal switch
So again its the harness for the 1 in the 4x4 location I need help with...
95BlackTahoe
Edinburg, PA
This should work for you...
The Plug...
The wiring...
In your case, It appears the follow applies for that horizontal switch...
Pin A Gray
Pin B Yellow
Pin C Nothing
Pin D Brown
Pin E Purple
Pin F Black
Hope this helps...
Shawn
sallimoservice
