Z95 Suspensión Help
AmunRoo
Chicago
Hey y'all! So I'm coming here for help because I'm trying to get my Escalade back to the factory z95 setup. I bought the Z95 struts and they came with the sensors that mount at the top of the strut. I don't have the male connectors anymore as the previous owner cut them off and added resistors. I'm not sure where to find these pigtails so that I can put them back into service. I found something close which would be the Delphi 2 pin connector with an angle flange mount. This is a description I found. The only problem is that it does look similar but I don't know if it will work. If anyone knows where I can get these pigtail connectors, I would greatly appreciate it or at least point me in the right direction. Pick included of the part I found.
As always, thank you for all the help.
petethepug
Michael
SoCal
Gotcha, 2013 ESV right? Yes, you can use those that plug straight in or they make a 90* too.
What type of replacements z95 did you purchase?
AmunRoo
AmunRoo
Chicago
Actually, no. It's a 2010 Escalade with the Z95. I need the factory male plug. The previous owner removed the factory plug and I'm trying to put it back.
I have set of connectors that a fellow Forum member sent to me, when I converted back to the Z55 suspension on my truck (the previous owner had converted to a lousy passive suspension). They did not properly fit my Z55 shocks, so perhaps, they were for Z95 shocks. If you want to try them out, send me a PM with your mailing address, and I will send them to you.
AmunRoo
AmunRoo
Chicago
Joseph, I appreciate the response. I really thank you for that. The connectors you posted aren't the ones that I'm looking for. I'll post a picture of the ones that I need. Hopefully someone on here knows where to get them.
Do you mean these connectors? :cool: @AmunRoo
petethepug
Michael
SoCal
Cool, friend’s & family deals on the TYF. Help someone with buying ‘em a mug and it’ll come back later as a kegger to you.
ziggy1949
