ilmk123
Hi ! Have a 06 Yukon Denali...The compressor and shocks are bad. I would just like to put coil overs on. Can somebody head me in the right direction? Thank you !
If you want to dump the compressor and air shocks, you have two options.Hi ! Have a 06 Yukon Denali...The compressor and shocks are bad. I would just like to put coil overs on. Can somebody head me in the right direction? Thank you !
Thank you for the info ! Yes I wan to get rid of compressor and air ride. I think I would prefer option 1. So I do have some questions. The zw7 is a RPO code? The self leveling shocks will adjust by them selfs driving down the road a few miles? Nothing else is needing for them to do this?If you want to dump the compressor and air shocks, you have two options.
1. Keep the rear springs and use Nivomat self-leveling shocks, 540-532. This is ZW7 with G65.
2. Install New HD rear springs and shocks, 45H2164 springs and 540-433 shocks. This is plain ZW7. Truck will sit higher in rear unless loaded.
You'll have to consult others about preventing warning lights and such from showing up on the dash, I just now the easy stuff!
Stock air shocks are 580-457 if you do not have 20 inch wheels. If you do have 20s, then it is either 580-458 or 580-203 depending on RPOs.
This Denali is my dads. He pulls a 3500 travel trailer with it. The compressor and shocks are bad. I am just trying to figure out away to get rid of the compressor and shocks. The rig in the avatar is my 05 2500 8.1 410 geared suburban. Pulling a 11000 travel trailer.You say that, but wait until you see the prices of those Nivomats. They are just as expensive, or more so, than the Z55/Z95 Air Ride.
Nivo
Z55
Z95
Cant find them..?
But I do have a query for you.. I see a mighty big trailer in your signature/avatar pic. Are you pulling that with this rig?
I personally would go back to a Z55 shock, without the electric pieces in it. Than replace the Air Compressor with a Dorman 949-099 (one of the only time you will see a Dorman part being recommended).
Air Comp
Shock with Z55 emulator kit built in
Arnott Air Suspension AS-3430 Arnott New OE Air Shocks and Struts | Summit Racing
Free Shipping - Arnott New OE Air Shocks and Struts with qualifying orders of $109. Shop Shocks and Struts at Summit Racing.www.summitracing.com
