Leaking fuel filler line
Stbentoak
Started to notice a drip on the garage floor that looked like oil. Slipped underneath, and see that it appears to be coming from the large fuel filler line that goes to the tank. The whole line is greasy and slippery from about the time it turned horizontal till it goes to the tank. Finally got bad enough that it dripped down on the frame crossmember and hit the ground. Anybody ever see anything like this?
Obviously a trip to the dealer is in order….
you can see the black spot on the frame.
StephenPT
St. Helens, OR
My guess would be that worm clamp has loosened a bit (classic problem with screw drive clamps). Also, I would shift it to the left by about 1/4". Clamps should be installed just after the bead on the tube. It's a bummer that access to the screw is on the wrong side (mine is the same orientation). I would put a box end wrench on it, loosen, turn 180, shift closer to the bead and retighten.
Stbentoak
Stbentoak
I'll let the dealer deal with it, just in case there is more to it than is obvious. Plus, I put a few more things on his list while it's in there.
89Suburban
Bull in the china shop
SE PA
At least it's not lifters like on the gassers! Sorry man.
Stbentoak
Stbentoak
Yep, the more I read, the more I sing those praises every day. Other than a few pesky problems non diesel related, the vehicle and especially the engine have been superb.
steiny93
Don't stay to much :)
Wife's diesel is down, waiting on a turbo, no eta on the parts; they thinking not January.
Stbentoak
Stbentoak
Well they said they’d call today and they didn’t,so I’m assuming no parts on fed ex … miss it and need it.
Not dealers fault tho….
Stbentoak
Stbentoak
Fuel neck replaced and all good there. The actual hose itself was split underneath the worm clamp....
While underneath the tech noticed the transmission cooler leaking and replaced that too. Pt # 24288625... Does engine coolant flow thru this exchanger? If so, that may be the cause of why my coolant was going low....Took over a week, but all good if everything is fixed....
wildvv
