Vibration at 80mph
Mishal
Hey guys
I recently replaced my shocks with new AC Delco shocks and have new tires and aligned together with Rod alignment and new steering shaft.
When I driver above 60 upto 80 I get too much vibration in the car where you feel the dashboard is shaking uncomfortably. Any suggestions will be appreciated thanks
rmaker
I bought a 2011 Suburban back in April. It had a horrendous shake at highway speeds, steering wheel shook. Turned out it was a bent drive shaft . Did u have the tires road force balanced?
Hoesgottaeat2
Western NY
Was it shaking like this before the work you mentioned was done? If not, I'd be looking at a wheel balance issue to start. Vibration only at certain speeds is typically indicative of the need for wheels to balanced.
M
Mishal
Yes it was shaking like this and I thought by replacing the shocks and arms and ball joints the problem will disappear but still there.
Multnomah Falls
Military
Knowing all this, from the beginning, would be a big help. Please, in the future, with any vehicle problems, it is best to share ALL info of before and after.
Dukk
