DuraYuk
- Joined
- Sep 17, 2022
- Posts
- 810
- Reaction score
- 584
Maybe I'm reading someone else's posts..or maybe you mean something different than what you post. Or maybe you are making generalizations using a small study sample.And yet you’re still saying I said things I didn’t. Absolutely hilarious. Try taking off your bias and read all my posts again. Maybe the you’ll actually understand the things I’ve said because everything you say I said is so far off base it isn’t even funny. I never said the Germans do it better, I said their suspensions aren’t crashy. My gosh you cannot read.
Sure, the older ones have problems. I’ve yet to see where I said they didn’t. But a 5 minute search doesn’t pull up a sea of threads on low mileage trucks all needing new engines. Not even in the K2 trucks!
It is totally fine that you don’t want an older vehicle, but just say that. Someone has to waste their money buying it new so I can buy used (not that I will ever be buying of these used, just to be clear). If you want a new vehicle and don’t GAF about how much it costs or anything else, go for it. It’s your money. That being said, that doesn’t make anything I’ve said not the truth because you don’t want to hear it and no matter how much you twist it to say something I never said. I’m not the only person in the world who thinks these newer trucks are insanely overpriced for the quality you get.
As for issues happening early you do realize that when things fail the likely hood of it failing sooner is higher than later from a production stand point ?
I literally pointed out everything you said and quoted it yet now your saying you don't mean those things? It's like the twilight zone.
I guess 100 posts about issues mean the production run of over 100k units every year since 2021 means they are all lemons. Good logic there.
I'm also pressing all over my wife's yukon to make it creak and Crack but I guess mine doesn't exhibit the issues your talking about. Must be a fluke. Just went thru Atlanta and didn't feel the crashyness....but guess that's a fluke too.. have 15k miles on it and put the cheapest def I can find in it but no errors... probably a fluke too.
Thankfully my wife's yukon is solid but by your logic it'd a fluke...gonna go play the lottery now and test my luck there....
Still curious to what your fond of? What is your vehicle of choice? 1991 camaro rs?
I'm not blind to issues either. We all know lifters on 6.2, but even that by the numbers is less than a few percent of total production. Look at other generations. They all have failing lifters. 10 speed is solid. Other generations all have way more transmission issues. Creaks and rattles? Maybe the occasional one here but far far from the norm. Look at other generations. Good luck. Crashyness? Don't think ive heard that ever except for some 22inch and performance models complaining of a stiff ride. Evaporator cores? Have not seen or heard of that until you mentioned it. I enjoy a good discussion but let's stick to the facts here.
You work at a dealer in ga? If you do I probably know all the people around you.
To get back to the OP the 6.2 is solid but has potential lifter issues. It's the performance choice no doubt. The duramax is much better on gas. Has much less chance of failures so far but does require a bit more maintained but nothing crazy.
Not really a bad choice either way.
