2001 TX Tahoe
- Joined
- Aug 22, 2014
- Posts
- 40
- Reaction score
- 13
Yes they keep everything the same, even the CV axles are left stock. They claim you can run 37's with some fender trimming. I don't really have a desire to go bigger than 35's at most.
Thats good to know! I've been debating between a soft shell and hard shell. I think I'm leaning that way now. I like fast.
This really has me thinking about my Yukon suspension now... and I just bought a TRX .
On your rear set-up, do the 2" Dobinson springs cause any issues with the track bar and/or control arm lengths or angles, or the driveshaft pinion angle? Which air bladders are you planning on using?
Regarding the front, how'd you decide on Izzy vs just coilovers with upper arms? Was it for the additional travel?
I see Izzy has the rack and pinion but they show it for 07-13... do they make one for our generation?
I had a Eaton E-Locker in my 2001 Tahoe. Worked flawlessly and no air lines or compressor required.
Regarding lights, hands down Baja Designs. I think they make better lights and customer service is superior to Rigid. For headlights, I swapped out the factory bulbs with Diode Dynamics LED bulbs and it made a huge difference.
