Broke door
Rob Yukon
I have a 2000 Yukon Denali. The rear cargo door on the drivers side is missing the piece that links the handle to the rods. I thought it was an e-clip, but that doesn’t seem to fit. I can’t find any pictures of it. Anyone know what it is and where to get it.
wjburken
Eastern Iowa
It looks like it clips on and wraps around the upper rod right??
Yes. I’m assuming there is a short 90° bend at the end of the rod. Insert the clip into the hole on the handle, press the 90° section of the rod into the clip and then swing the clip down to lock in to the main section of the rod.
wjburken
Eastern Iowa
Here is a picture of the same style clip on a truck tailgate handle. You can see where the clip goes into the hole, then the rod is pressed in, locking the clip into the hole, then the clip is rotated to snap onto the main rod.
Gator Aggie
