5inch rcx lift on 17s fitment?
Deityrider69
alright guys i have a 2008 tahoe 2wd im putting a 5inch rcx lift on it. my question is will i have to run spacers if so what size? rough country states online there kit is recommended for 18" or larger wheels. my wheel and tire specs are 17x9 -6mm offset 4.75 backspace on 285/70/17s. even though roughcountry states that there are many who run that lift with 17s and 33s or 35s. my only thing im trying to figure out is if they will rub on knuckle or something else. also trying to make sure wheels are even with front after lift. thank you
Trey Hardy
Eastern North Carolina
You’ll need atleast 1/4” spacers for the front to clear the uca on stock or no offset wheels
Trey Hardy
Ex
also if I’m not mistaken you’ll need 1.5”-2” spacers in the rear to get them even with the front because the knuckles pushes the front out more
I got 2” in the rear of mine and if I did .5” spacers up front they would be perfect
Deityrider69
Deityrider69
Ex
ok perfect thank you the rough country rep told me 2"spacers for front and back. but that didnt make sense to me since kit already pushes fronts out further
Trey Hardy
Definitely not
2” spacers in the back and 1/2” up front should be even
I say 2” because I believe you have to trim your wheel studs shorter running 1.5” spacers
Deityrider69
Deityrider69
Definitely not
ill go with that then thank you so much for the help!:cool:
Trey Hardy
Also the 5-6” is essentially the same as the 7.5” so if you wanted to run 35s/37s in the future just throw a 2” leveling kit under the strut or get some lift struts for a 7.5”
The 7.5” is just the 5-6” kit stretched out all components are the same I adjusted mine from 9” to 7.5” down to 5” on my Silverado as she went through her stages…
Deityrider69
Deityrider69
good to know thanks again im sure mine will she many stages as well lol
BattleTank
