Tires, lifts, spacers, and the combination
88lance
2002 Z71 4x4 Tahoe.
Wanting to run 33x12.50, with a level. I'm not trying to crank the keys way up, just enough to bring it level with the back.
I have stock wheels, so some spacers may be required.
This guy is running 12.50's on the same rims but has 2" spacers on the back.
Does anyone know if I can use something smaller such as a 1 or 1.5 spacer in the back, or is the full 2" really what it takes to clear?
The front tires on these sit in slightly more than the rear stock, So if I could do something like a 1.5 on the front and a 1 on the back it would kind of even it out.
Just wondered if anyone knew what the minimums are.
As far as height goes, I shouldn't have a problem. If he's clearing 35 with a level, I would think my 33s should be good. I noticed he has a lift in the rear, but he's also running tires 2 inches taller, So I'm thinking I should be able to get 33s with stock rear height.
Can anyone tell me what the minimum spacer sizes are for a 12.50 with a level? Any other things I may be missing?
Alex_M
Spacers with that size tire are going to actually cause interference issues with the front bumper and possibly the fender as well because they will increase the swing of the tire from the pivot point at the ball joints. Without spacers you may swing it with only minor rubbing.
Look at some 285/70r17s which are 33" but a bit narrower; closer to an 11.5 width. You can run them with no spacers or a 1.25" spacer in the front and no spacer in the rear with stock keys cranked up.
The truck you posted has aftermarket lift keys in the front which is helping him clear that wide of a tire and it looks like he has only rear spacers, no front spacers.
Alex_M
Ah, he has 1" front spacers. That tracks. My Tahoe on 35s is a similar setup to his but narrower tires and a little less lift in the front. Same height keys but not cranked up as high. For 35s (more specifically 285/75r18s) I have 1.25" front wheel spacers with 3" keys cranked about half way, and 1.5" rear spacers with 3" coil spacers and sagged out coil springs from lots of heavy towing duty the first year or two I had it.
88lance
88lance
I forgot to mention, I ordered aftermarket keys as well. So I will be running a similar setup to what he has, except I will not be cranking them up as high since I'm not lifting the back as well.
I will just raise the front up to be level with the stock rear.
As far as clearing width goes, the guy in the video is running 12.50's and clearing, but I wonder if it's just because he cranked the keys up all the way...
The 2" less in height should help me since I'm going 33 instead of 35, but I'm not sure if the 12.50 has to have full crank on the keys to even work possibly?
It would be great if I could just raise it the 2" to level with the back and clear the 12.50's somehow.
Alex_M
I'd recommend cranking the stock keys first to see if you need more height. Usually that will set it pretty close to level with the rear and you'll save yourself the headache of swapping the keys. If you still want more height then you haven't costed yourself any more than a few minutes under your truck.
There are a lot of variables at play here. I'd question why you're stuck on a 12.50 width - you'll save on tires and see better performance for less work with a 285/70r17 while still getting the same height.
If you're dead set on a 12.50 wide tire, you may be forced to go taller. Whatever you do, please remember to re-aim your headlights so the cutoff is below the windshield of oncoming traffic, especially small cars.
88lance
88lance
The stock keys are maxed out, and the front is still 2" lower unfortunately. So the torsion bars may just be worn out. I ordered the aftermarket keys, so I guess I'll see how it rides with those, hopefully I don't end up having to replace the bars.
I just really like the 33x12.50 because it has a good wide stance. Once they started getting towards 35" on an 11 wide they start looking too thin for my liking.
If this starts looking too complicated, I may need to just get the 285/70's and call it good though.
Alex_M
Understood. Yes, sounds like your torsion bars have sagged some. Not an issue, the replacement keys will solve that in that case.
I have the opposite inclination - always been more a fan of a tall skinny tire. To each their own though. When you get them sorted out post back what you ended up getting to work.
88lance
88lance
This photo below is pretty much exactly what I'm shooting for. Those have got to be 12.50 wide for sure, and running stock wheels. It's a shame that I don't know whose it is to ask what they had to do as far as spacing and all that.
I had an idea, I may take one of my wheels and tire off, and put the spare on at the moment. Find an old used worn out 33/12.50 and mount it on my good wheel, and bring it back to the house.
Then I can put it on the front and see what it needs, and then put it on the back and see what it needs..
With the truck raised up by the control arm, the weight of the truck will still have the suspension compressed. So it should be the same as if the truck was sitting on the ground. I could do something like put a 1.5" wood block across the lugs and mount the tire on top of the board, and then turn the wheel from lock to lock and see if and where it touches, or where it may touch if the suspension compresses more. This may tell me what size adapters I would need on the front and back.
That way I don't have all the tires mounted and find out that I can't drive it until I order and wait on adapters to be delivered while the truck sits on blocks.
The photo below looks like He's not having to run very much spacing though.
Alex_M
Couple things. First, a worn out tire will be dimensionally smaller than a new tire so you will not get an accurate read. Second, your lug studs are not long enough to have a 1.5" block of wood between the hub and the wheel. Third, the suspension moves some back and forth under acceleration and braking because of the give in the bushings.
I think you're on the right track with the keys and 1.25" wheel spacers - it's just going to be a matter of how high you have to adjust it. Also remember, with wheel spacers that thin you will have to cut the unthreaded first half an inch off each lug stud with an angle grinder.
Even your alignment will effect clearancing, though I've generally gained a little clearance when getting an alignment so you should be all right there.
88lance
88lance
Good points. I may just have to get as close as I can guesstimate with the old tire by messing with it some, order an adapter, and actually mount and try it. If it works, order the rest. If it doesn't, hopefully I would be able to tell what I needed to correct it from that.
On the black Tahoe it looks like the rear doesn't have any spacing, and the front seems to be spaced a little bit.
So I'm not sure why the guy in the video spaced the rear two whole inches, unless he just wanted that look, or had something to do with the two extra inches in tire height somehow. Hopefully I don't have to run adapters that thick.
I noticed you have some pretty big tires on yours, maybe a little bit thinner though like you mentioned. What did you have to do with yours?
Buzarr
