I feel a clunk from a stop.
BUCKSATH
Hi all. I tried to search around, but I couldn’t find exactly what I was looking for. I’ve got a slight “clunk feel” coming from my wife’s 17 5.3 LT suburban with 150k. So it’s not a noise it’s just a “feel” when I take off from a stop. I haven’t checked the u joints yet but could it be anything else? Any help would be appreciated.
Broken driver side engine mount? It often feels and sounds like it's coming from behind you.
Pop the hood and powerbrake it while you watch the engine from the gap where the back of the hood meets the cowl.
B
BUCKSATH
Maybe the slip yoke at the trans output shaft. Used to be common years back. If the splines get dry or worn, they can make noise, or feel like a clunk when it moves under acceleration
I’ll check that out.
B
BUCKSATH
Man I never would have guessed that but I’ll definitely take a look. Thanks
Rokjhn
My 2011 Avalanche had similar “clunk” and it was the drivers side motor mount. Common problem with GM trucks\SUV’s and a relatively easy fix.
Ohannon7
Central Fl
2019 Yukon XL here with a blown driver side motor mount due to increased stress on lowered vehicles (I think).
I don't want to spend $700 on an OEM mount bc it will blow again. Historically I upgraded to Energy Suspension urethane mounts but they don't make them for my Yukon so IDK what to do. Are others going OEM or aftermarket? TYVM & good luck OP!
gsmith
