Random driveline clunk when accelerating from a full stop
KC 2013 Tahoe
Chandler, Arizona
2013 Tahoe, 5.3L, 127K miles.
Bought her used at ~46K miles.
I change the engine oil/filter every 4K miles, Trans fluid/filter every 2 years, transfer case and diff's every year.
Engine runs and idles smoothly, right at 500RPM in Drive per the dash tach.
When pulling away from a traffic light from idle, we'll periodically get a solid "clunk" that you can feel. (probably 1 out of every 4 times)
Feels like its coming from transfer case area but not certain.
Started doing this about a year after getting her, but never have been able to detect where its coming from, nor has it caused any problems.
It's very mild under a light throttle, but very pronounced if you hit the gas hard, say to pull out onto a major street.
Again, the odd thing is that it's periodic and doesn't do this every time.
FWIW, we had the Trans and Torque converter rebuilt 2 years ago at 110K miles after the converter failed. Made no difference at all.
Saw some posts about older models having a slip yoke binding issue, but 2013 was supposed to be well after those issues.
When I'm underneath to service it, there's no unusual play in the driveshafts either to the front or rear diff's.
It's hard to tell exactly, but does feel as if its coming from the transfer case area.
What really stumps me is the periodic nature. If it was wear, would think it would do this every time.
Also seems odd, as I believe the driveline is loaded-up when idling in gear. So even if there is drivelline slop, the preload from the trans being in gear while idling should keep any lash from being felt. Very odd.
Kevin
Kevin
motor mounts and front diff mounts are both known to cause this as well a broken or missing sway bar end link
KC 2013 Tahoe
KC 2013 Tahoe
Chandler, Arizona
Guys - Thanks so much for your spot-on advice!
Brake torqued the engine with the hood up and couldn't believe how much it moved... I could make it "thunk" on command with the accelerator. O'Reilly had 1 mount that I bought yesterday, with the other arriving today.
Those suckers list at $90 but with my discount they were $37.15 each (I have a small side business working on collector cars).
Will be replacing them Saturday and will let you all know how it goes.
BTW - The front sway bar bushings and end links looked OK, but could stand a refresh after 11 years of Arizona summer heat.
Didn't get to the front diff mounts, but will check them when I'm under there doing this.
Thanks again for the great advice!
Kevin
Power Torque Engine Mount​
Line: PTQ Item: C3211
https://www.tahoeyukonforum.com/javascript:void(0)
j91z28d1
Kevin
watch some youtube videos. it looks like a rough install.
let us know how it goes, I've been putting mine off but I'm sure it needs them like they all do
TU1881
