Oil leak
Dustin Jackson
True it could be a coolant leak that’s soaking up oil making it look dark.
89Suburban
Bull in the china shop
SE PA
@89Suburban does it leave oil spots on the ground? The thing about my leak is it wasn’t showing up on my driveway
Oh yeah big time, all over the frame too. It will leave a couple dollar bill sized spots overnight. Everything has been resealed except the front and rear mains/covers and oil pan. Oil pan and gasket will be next see how much that slows it down. Replace o-ring and install oil deflector. After that I will just run it whatever it is until I replace the motor.
89Suburban
SE PA
Could it be slinging off the front seal behind the crank pulley? Could it possibly be the weep hole on the water pump weeping?
OP did you do a fell/taste/smell test to confirm if it is oil or coolant?
03GMCYukonXL
Well I do have spots on the ground and it's all over the starter. It's definitely oil. But, I suspect i have a slight coolant leak as well that I've had since I got the truck. It's incredibly slow though. I may just get my suburban up and going and just really dive into this thing.
As far as the oild slinging, I suspect that as well but there is no oil on my belts at all
sylentnite
