mikez71
- Joined
- Mar 9, 2023
- Posts
- 828
- Reaction score
- 961
Just did driver's side, not toooo bad.
Kinda easy, kinda worried, tired and scraped up feeling after I was done.
jack up truck / put on stands
remove wheel (6 nuts)
remove inner fender liner (4? 7mm screws and maybe 8? or so push pins) a few electrical plugs (push them up with a pliers)
crank steering wheel one way (so you can't possibly clock anything wrong) and remove steering coupler (2 bolts)
destroy mount heatshield so you can see the bolts to block
jack up engine on that side
Now you need the right short extensions/wobbles/angle ratchets whatever to loosen the 7 bolts.
and wiggle the mount out of there!
The H3 mount does have a sleeker heatshield which may make installation a tiny bit easier.
Passenger side looks like starter needs to come out...
