New member/new Tahoe owner here (2010 LTZ)! Loving it so far, but getting the runaround on a repair quote and also have a few questions in general.
D
DamThatRiver24
Laramie, Wyoming
Yea, like I said I've lurked here for the short while I've owned it and this forum has been a blessing...with an answer to pretty much every stupid little question or curiosity I've had without even having to post (until now, lol).
In my experience most major chassis gens from the major manufacturers have pretty helpful forums. I had a GMT 400 that I had to lean on the forums quite a bit for and they were quite helpful (I'd imagine there's probably some crossover here). I've also owned several Ford Fusions and those forums were hopping for a few years, but have died down recently (fortunately for me, my last Fusion standing just blew up and I don't forsee owning another one).
Well, Tahoe is in the shop this morning getting the trans taken care of; GM dealership wanted almost $500 (lmao) but the new local AAMCO is $270 and I'm looking for a new shop for stuff I can't/don't want to do anyway...so we're giving them a shot.
Was gonna do the compressor/shocks this weekend but y'all scared me into doing the tranny first, lol. Guess I'll do those next week or so. Speaking of the shocks, I think I'm gonna try that Vigor company; they seem to have good reviews (including a couple from folks here) and they're like 1/3 of the price of the Arnotts. Even if they don't last terribly long they're dirt cheap and look pretty easy to swap, so I figure I'll give it a go. They make a compressor too, but I'm gonna stick with the Dorman just to avoid any issues.
Side question: what kind of overall mileage do you guys tend to get with these things? Mine seems to range from 12-16 MPG (city) depending on how cold it is, if I have to use 4x4, etc. Seems about in the ballpark for a 5.3L V8, yea? My 2003 F150 XLT (5.4L V8) gets about 10-12 city, 8 mpg if I have to use 4x4 for any length of time lol.
I do need to do the plugs and wires and probably slap a new air filter in it, but yea.
My Yukon XL weighs about a 1,000 pounds more than yours and gets 12.6 MPG with 100% city driving and averages 15.6 mpg with 50/50 city/hwy driving. That's 1.3 to 2.2 gallons per hour running around town and such.
2010s seemed to have unique tuning and got better mileage than all the other years.
D
DamThatRiver24
Laramie, Wyoming
Fair. After I do the plugs/wires/air filter/shocks etc. I'll pay a bit closer attention. Doesn't seem like I'm too far off; the lower end of the range I gave has usually been in colder weather with a fair amount of idle time and all of the aforementioned parts needing replaced (as well as being prior to the trans service today).
I do live at 7200 feet elevation fwiw, though I suppose elevation's effect on gas mileage is highly debated. Lol.
I installed the Vigor air shocks and new Dorman compressor about a year ago and they've been great.
Good to know; pretty much solidifies that decision.
In other news, the shop today did catch a very small leak from the rack that I hadn't noticed; hopefully it stays manageable for a while until I can deal with that this summer.
For those of you who use 4x4 quite a bit, how often are y'all doing your transfer case?
D
DamThatRiver24
Laramie, Wyoming
Shop raised a red flag about my oil levels while doing their "complimentary inspection" yesterday, said that I was close to 2 quarts low.
Changed the oil about 2000 miles ago (first oil change under our ownership) and I know for a fact I put 6 qts in it. However, I admittedly forgot to check the level on the dipstick afterwards (usually routine for me but I think I was in a rush, my fault entirely).
There are no visible leaks underneath the vehicle or in the engine bay, and there's no obvious burnoff in the exhaust (don't see or smell anything unusual). I also seem to recall reading that we have a low oil level warning that kicks on at 1.5 or 2 qts low, which hasn't happened.
This is what the dipstick reads after sitting for 24 hours in 25°F weather. Seem like a major concern to y'all?
Gonna change the oil again this week and of course keep a hawk's eye on levels, but just figured I'd toss this out here in the meantime. I do understand that there's some consumption to be expected with the AFM, correct?
D
DamThatRiver24
Laramie, Wyoming
Also not really happy with how dirty the oil is after only 2k miles; not sure how well the oil was maintained under previous ownership but I'm going to give it a couple more cycles to flush crap out of it and if it's still getting dirty prematurely I'll send a sample off for testing.
Geotrash
Dave
Richmond, VA
That would be considered normal by GM but not the rest of us. Mine both use maybe half a quart between 4-5K mile changes. Oil consumption on these usually comes from stuck rings due to the bypass valve in the oil pan spraying the underside of the a couple of the pistons, but yours should have the deflector installed already being a 2010. Another common reason is the PCV system. There's a revised drivers side valve cover that has a different baffle design that solves most of the problem, but again I think a 2010 SHOULD have that already. You might consider installing a catch can. Lots of examples on here and people swear by them.
D
DamThatRiver24
Laramie, Wyoming
So I changed the oil today and a touch over 5.5 qts came out, so a) the guys at the new shop (who claimed it was almost two quarts low) might not be the brightest, and b) the dipstick is definitely "approximate". Lol. Not too worried.
Was definitely darker than I wanted to see after only 2k, but it wasn't abnormally thick and fwiw there's no glitter or anything alarming in the old oil, so meh. Maybe just getting a bit more blow-by than expected, or there's still a tad bit of old sludge in there from a previous lack of maintenance. Idk.
Yukon DRL
