Shocks and spacers
Yukon2007
I have a 2007 Yukon I need new shocks I’d like to add 2 inch spacers to the rear I’m looking at the Rancho rs5000x would I still need the spacers to get any lift ?
Y
Yukon2007
These are the ones I’m asking about
Dustin Jackson
@Yukon2007 All lift is achieved from longer springs or spring spacers. If you plan on lifting it 2 inches I recommend buying shocks that are designed for lifted Tahoes or use shock extension brackets. If you use stock height shocks with a lift the shocks will not perform very well
Y
Yukon2007
Ok thank you the ones I posted are for up to a 4 inch lift
Dustin Jackson
@Yukon2007 Those should be ok. Might be worth the money to bump up to bilstein shocks I havne't heard good things about Ranchos
Tozan
Overlander
Yavapai Arizona
I ran Ranchos they lasted about 4 years.. They work pretty good but, Kings work much better and they are rebuild-able too.
