Thrust
ICT
4 new tires and an alignment. I know there are some Michelin Man nut swingers on here but you need to take a look at Mastercraft Courser Quest Plus. I have a set on my truck and they are great so far. Made by Cooper Tires.
Replaced the Bridgestone tires that were on our Denali XL. I think Bridgestone's quality has gone down as we had a set on our 2008 Escalade and loved them. But this set wore faster and had a vibration at 75mph +.
Sparksalot
Bastrop County, Texas
Well chit, the 3rd brake light has failed. I had noticed condensation inside the lens recently. It did pass annual inspection a couple of weeks ago.
Looks like the GM part is 22783104.
Jeff_
Scottsdale, AZ & N. Idaho
the ANC shouldn't stop the sub from working, all it would do is cause some undesirable feedback, kind of like having a mic to close to a speaker and instead of a high pitch squeal you would get a rumble. double check your work.
Well I ripped apart my interior and installed my Kicker sub. Followed every single instruction exactly.
Turned on some music and the sub itself makes no sound..
I'm unsure if it's because I need to go to the dealer and have them eliminate the ANC (active noise cancelation) through a reprogram. I know the installation manual says to do that. But I figured it would still work somewhat before having that done and then just be optimized after that was disabled.
Fingers crossed that all I need is the quick trip to the dealer and to pay $50 for them to reprogram in order to get this sub to function..
(pic of things torn apart for your enjoyment)
I took it all apart again and reattached where I spliced and then crimped on the sub wires this time. (Terrible instructions at that part from Kicker)
Working well now, definitely added some thump to it like I was looking for! Happy with it now.
bl74
