Alex_M
- Joined
- Sep 27, 2021
- Posts
- 358
- Reaction score
- 656
You're welcome to think what you like. Your continual insistence that I told him to use 4lo all the time comes off as sounding like someone with poor reading comprehension skills. As I stated and reiterated, "where you need 4wd".your statement of leaving it in 4lo comes off as sounding like someone that has "maybe" been off road, barely. not someone with years of "heavy" off roading, you should know well it completely depends on the terrain and circumstance. Besides I don't think there going to be attempting to crawl rocks on there first trip to a off road park with a stock rig, it will most likely be a learning experience which will be where you get to "find out" if you should use 2wd/4wd/4lo given the particular circumstance.
I would never tell someone ya just use 4lo all the time off road, no.......... because it completely depends on if it is wet, dry, ice, snow, rocks, sand, mud, small hill, big hill, giant hill, downhill etc.
Of the terrains you listed, the only one I'd choose 4hi would be ice and sometimes snow because it will make the truck less responsive to throttle input in slick conditions. All the rest, if 4wd is necessary because I am not making it in we, then I'd take 4lo because of the torque multiplication and saving wear and keeping heat out of the transmission. If you need more wheel speed then you can shift to 2nd, but the extra torque is going to help you from a stop and prevent you from getting bogged down in all other terrains.
Again, I don't see the point in this chest beating. You're sharing your perspective, I'm sharing my perspective. I'd be happy to learn whatever knowledge you might have that I lack based on experience, but otherwise - why not live and let live?
I'm not going to continue this discussion following this because you seem more interested in being right than in having a genuinely constructive cost/benefit discussion.
