06 Front sway bar bushings
donnied
I want to replace the front sway bar bushings. i measured my sway bar, it is 32mm.
the moog replacement is moog-k7326, 31.75mm with bracket. the old bracket and the included bracket are different sizes and the new bushing doesn't have material overhanging the bracket like the old.
i don't like the egg shaped holes in the new bracket. i can get the 10mm bolts centered best i can, but would that hold up and not shift to one end or the other in the bracket over time?
the originals look exactly like moog-k6439 and the original bracket fits but those are 33.5mm
should i use the larger bushing with with old bracket or the new bushing with new bracket?
it's not really going to matter if the bushing has a little gap from being slightly smaller, probably better to use the smaller size than have it be loose with a oversize.
just put some grease all over inside during install and you should be good to go.
jguzman90
